1993 Mercury Tracer Car cranks, but won't start
118,000 MILES • 4 CYL • FWD • AUTOMATIC
DJT111460
Car cranks, but won't start.
Yesterday my car started fine.
I just warmed it up but did not drive it.
Today I tried starting it and it didn't want to turn over.
Any suggestions?
Dec 28, 2008 at 7:04 AM
  • 75,988 POSTS
When it refuses to start-do below and tell me what happened
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Dec 28, 2008 at 7:11 AM
