My tracers cooling fan stays on and eventually burns out the fan control relay in the engine compartment fuse box. The coil side of the relay stays engergized all the time when the key is turned on and if you jump it it will try to start the engine. also the fan is not controled be the A/C switch when it is turned on.
Thanks for any help you can give me. John
Jun 18, 2006 at 2:34 AM
