1991 Mercury Tracer HEATER CORE REPLACEMENT
1991 MERCURY TRACER
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
HOOPT
According to my Chilton's manual, there are only 8 steps to the point of removing the housing unit.
But, there is nothing in the manual about what other components have to be removed.
My question is how many other components must be moved out of the way in order to get the housing unit out?
Dec 28, 2007 at 7:47 AM
FAIRRACING31
  • 150 POSTS
1. Disconnect the neg. battery cable 2. Drain the cooling system 3. Disconnect the heater hoses at the firewall 4. Remove the instrument panel 5. Disconnect the mode selector and temprature control cables from the cams and retaining clips 6. Remove the necessary defroster duct screws and loosen the capscrew that secures the heater-to-blower clamp 7. Remove the three heater unit mounting nuts and disconnect the antenna lead from the retaining clip. 8. Remove heater unit 9. Remove the insulator and the four brace capscrew 10. Remove the brace 11. Remove the heater core from heater unit.
https://images.2carpros.com/forum/automotive_pictures/103836_0900823d8013c478_1.jpg
Dec 28, 2007 at 8:30 AM
