1991 Mercury Tracer cranks but wont run
945,674 MILES • 4 CYL • FWD • AUTOMATIC
KWATONG914
I have a 1991 Mercury tracer that will crank but wont run.Replaced timing belt,drive belt,ignition coill,spark plug wires,ignition relays,fuses and the fuel pump runs and there is fuel in the lines. The battery is full but still the engine wont run.
Apr 3, 2010 at 8:03 AM
  • 75,988 POSTS
Do below to determine if its a fuel or spark problem and then get back with some results we start herre.
Apr 3, 2010 at 8:21 AM
