fuel pump relay
1988 MERCURY TRACER
JMPADGETT
1988 Mercury Tracer 4 cyl Front Wheel Drive Manual
can you tell me where the fuel pump relay is located and also I have power on both sides of inertia switch but none to fuel pump.
Jul 13, 2008 at 9:39 AM
  • 55,423 POSTS
The fuel pump relay is located under the hood near the fire wall on the passenger side.
Here is a diagram to show you
Please let me know if you need anything else to get the problem fixed.
Best, Ken
Mar 17, 2017 at 5:57 AM
AZREAL
This is my original question...
I have a 1989 Mercury Tracer. It has been an awesome car up to this point. A few days ago it died in the middle of the road. I have replaced the fuel pump already. However it is not getting electricity to the new pump. I have spent 2 whole days looking for the relay. Can someone please help me? I have searched the engine compartment, fuse panel area, and in the center area of the dashboard. Could it be anywhere else? I truly appreciate any help offered.
I was offered this solution...
(I found an image of the fuel pump relay on this very site, here's the address:
https://www.2carpros.com/questions/mercury-tracer-1989-mercury-tracer-fuel-pump-and-fuel-pump-relay-switch
It could also be the fuel pump shut-off switch (inertia switch).
The Inertia Fuel shut-off (IFS) switch must be manually reset.
The IFS switch is located on the RH side of the luggage compartment. Access is gained through a hole in the luggage compartment back lower trim cover
To reset the IFS switch, depress the button on top of the IFS switch.)
I had seen this posting prior to asking my question. However, this information is incorrect. I have completely taken apart the underside of the dash. It is not located where this diagram indicates. Please HELP!!!!
Mar 17, 2017 at 5:58 AM (Merged)
AZREAL
FREEMBA
  • 1,152 POSTS
LOSBOZOS
My tracer will not start after installing a new fuel pump and I cannot find where the fuel pump relay switch is located. Please help!
Dec 31, 2019 at 4:25 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
Under the dash at the top edge of the carpet.
https://images.2carpros.com/forum/automotive_pictures/561653_Fuel_pump_relay_89_Tracer_1.jpg
1. Disconnect battery ground cable. 2. Pull rearward on the front edges of the center carpet panel and disengage the push pin retainers. 3. Remove attaching screw and carpet panel. 4. Disconnect the relay electrical connector. 5. Remove relay retaining bolt and the relay. 6. Reverse procedure to install.
DEAN VERMITE
Wrong. Haven't found it yet, but it is NOT located where the above diagram shows it is.
  • 55,423 POSTS
They have this note with the location
FUEL PUMP RELAY (LESS A/C): Behind LH side of instrument panel.
FUEL PUMP RELAY (WITH A/C): Behind RH side of instrument panel.
Please let us know what you find.
Cheers, Ken
