1993 Mercury Topaz Engine noise...
12,600 MILES • 4 CYL • FWD • AUTOMATIC
DPWDAVE
1993 Topaz has a metallic rattle that seems to be coming from under the valve cover at idle. The slightest acceleration (50-100 rpm increase), and the noise disappears. Stays gone during normal driving until you return to idle, the the rattle returns. This is with the engine at operating temperature. I believe the noise is there at cold start also. Bear in mind it is not real cold in Michigan yet...
Oct 29, 2009 at 8:24 AM
FIREBIRD68
i have the same problem with 1994 topaze did you ever find the problem
Nov 16, 2010 at 8:40 PM
