1991 Mercury Topaz strut removal
1991 MERCURY TOPAZ
180,000 MILES • 4 CYL • FWD • AUTOMATIC
HOLLYWOOD1962
I have a 1991 Mercury Topaz and when I was changing the front brakes I stripped the spindle. I went to the wrecker and picked up a new one that came with a new strut. I am having a problem with the ball joint and the strut. How do I get the strut out and will this help get the ball joint out? I have all the bolts out and just need to get the strut out. If I use a #18 socket I can turn the bolt that holds the strut but everything turns with it. HELP.
Feb 12, 2008 at 11:57 AM
MASTERTECHTIM
  • 4,750 POSTS
your not talking about the bolt on the top of the strut i hope. if you have the ball joint un bolted you need to hit it really hard where it connects to the spindle to jar it loose.
Feb 12, 2008 at 12:02 PM
HOLLYWOOD1962
[quote:8363cf9713="mastertechtim"]your not talking about the bolt on the top of the strut i hope. if you have the ball joint un bolted you need to hit it really hard where it connects to the spindle to jar it loose.[/quote:8363cf9713]
Yes I'm talking about the bolt on top of the strut. Did I do something wrong? I hit the ball joint hard and was able to get it out half was. I was talking to a friend and he said to use a long prybar on the control arm and push the ball joint out the rest of the way. Am I on the right path?
Feb 12, 2008 at 1:31 PM
