1991 Mercury Topaz changing front shock
1991 MERCURY TOPAZ
180,000 MILES • 4 CYL • FWD • AUTOMATIC
HOLLYWOOD1962
How do I get the bolt off the top that holds the front shock in place? I use the proper socket but it just turns.
Feb 16, 2008 at 1:45 AM
MERLIN2021
  • 17,250 POSTS
Do NOT remove that nut in the middle!!!! Undo the bolt at the knuckle tap downward until the strut comes free from the knuckle, then remove the three small nuts on top, the strut assemblly now can be removed, use a spring compressor to compress the coil spring, use an air gun to remove that canter nut, AFTER the tension is off using the spring compressor! Make sure you know how the old sturut and spring align, Align the new strut and old spring and tighten down the cap, relieve tension on the coil spring...reinstall the strut! DO NOT put your face anywhere near the front of a compressed spring, if the tool fails, you will be SERIUOSLY injured!
Feb 16, 2008 at 2:03 AM
