When replacing the battery, I got the wrong model and connected the battery backward backwards. The terminals were reversed. The horn sounded and I realized the problem and I disconnected it. After connecting the battery properly, I started the car and the radio wouldn't work. i replaced a blown fuse, the it was fine. Two problems remain.
1) The car heater doesn't produce any heat and
2) the battery is not charging.
I couldn't find any other blown fuses, but there are other square relays/fuses that have four connectors that I do not know how to check. What do you suggest?
Feb 5, 2010 at 9:56 AM
