2000 Mercury Station Wagon Antenna
103,771 MILES • 6 CYL • FWD • AUTOMATIC
MORNINGLORY721
The antenna will not go up but I hear clicking noise when I turn radio on as though it is trying to work correctly. Any help would be greatly apprecaited
Thank you for your time
Feb 27, 2009 at 9:01 AM
  • 110,248 POSTS
Hi:
the motor needs replaced. Chances are a gear has gone bad in it and that is the clicking you hear.
Feb 27, 2009 at 10:37 AM
MORNINGLORY721
[quote:f0d23973a6="Jacobandnickolas"]Hi:
Joe[/quote:f0d23973a6]
Is there no other possible cause as I know replacing the motor will be very expensive and can't afford at this time.
Mar 2, 2009 at 5:11 AM
  • 110,248 POSTS
Hi:
That is the only thing that I am familiar with. If you get a motor from a salvage yard, you could try to do it yourself. Or, just raise the antenna all the way and unplug the motor.
Mar 2, 2009 at 5:48 AM
