I have a Grand Marquis that when I step on the brake, It goes to the floor when the engine is running, when the engine is off, the pedal is "tight" hard to push to the floor. I replace the Master cylinder, Bleeds the lines on all four wheels and check the "Vacuum check valve" which is o.k.
May 1, 2009 at 2:45 PM
