Starter not turning over, only clicking.
DGREIVES
  • MERCURY SABLE
I have a 2000 Sable, with 104,000 miles, and it just suddenly would not start. When the ignition key was turned the starter would just make a single click. The battery is fully charged, relay was checked, and starter was replaced. But, with the same results. Can you help with were I should look next?
Monday, September 17th, 2007 AT 6:26 PM
BMRFIXIT
  • 19,053 POSTS
HI THERE
if no alarm in the car
have you checked the oil !
You should start with the battery terminal and the ground cable.
And check that starter again if all wires ok
good luck
Monday, September 17th, 2007 AT 6:42 PM
