2003 Mercury Sable GS, 68500 miles, 3.0L V6 (automatic transmission)
When I start my vehicle (hot or cold start), I notice a grinding noise associated with the starter. More than half of the time, a rough (spitting and sputtering) idle follows. The idle is very low and literally shakes the car. It seems that the engine could die at any time, but doesn't. I never get a 'check engine' light either. This condition typically lasts 30 seconds to 3 minutes, or until I push the accelerator (in park or drive) so that the engine reaches ~3000rpm or greater. Once the engine gets past this issue, the car runs fine. One source I spoke with thought it could be related to the idle solenoid on the starter sticking (not engaging the flywheel) or a temperature sensor. I'm not sure how accurate this might be.
On an unrelated issue, at any environmental setting (vent, a/c, heat) I use, I smell gas fumes. They are potent enough to cause health concerns and I have no idea why they are being directed as such (into the interior of the car).
Thank you for your help!
May 14, 2007 at 3:14 PM
