2004 Mercury Sable Coolant in Transmission Fix
STOTTSS
I have a 2004 Mercury Sable with 75,000 miles and a 3L engine. I took it to Domestic Auto Experts for regular maintainence. They did an oil change, replaced air, cabin air and fuel filters, and flushed the power steering and did a transmission flush and service. When I picked up the car I noticed a coolant smell after a few miles, an the transmission was not operating smoothly. the next day when I arrived at work, transmission fluid began pouring on the ground, and coolant was spewing from the resevoir hose. The mechanic says this is from a hole in the radiator and is not in any way[img:f589016df9]http://www.2carpros.com/forum/automotive_pictures/72444_19373_Stotts_004_1.jpg[/img:f589016df9] caused or connected to the service they performed. Can they have possibly done somthing to cause water to enter into the transmission?
May 4, 2007 at 7:12 AM
MERLIN2021
  • 17,250 POSTS
If they did a coolant flush, or you got you heater core flushed, and the coolant line from the core to the rear of the engine was disconnected, it may have caused the dipstick to pop up and allow the coolant to enter the tranny! Happened to mine!
Tranny clutch material gets wiped out by the anti-freeze. Big Bucks to fix...sorry...
May 4, 2007 at 9:13 AM
Suggested Repair
Have the transmission checked for coolant contamination. If a heater-core or coolant line was disconnected and the dipstick popped up, antifreeze can enter and destroy clutch material, often requiring a costly rebuild or replacement. Also verify whether the radiator has a leak as the shop claims.
Conversation Summary
The owner of a 2004 Mercury Sable noticed a coolant smell, rough shifting, a transmission-fluid leak, and coolant spraying from the reservoir hose after a shop service that included a transmission flush. The shop blamed an unrelated radiator hole. The expert said a disconnected heater-core coolant line can pop up the dipstick and let coolant into the transmission, which ruins clutch material and is expensive to repair.
