Car Not Starting
R TOWNSNED
I have the same problem as another person about the fuel pump, but I have a bit of a twist. I pushed the off switch button and gasoline came through the lines. Instead of the gas pump not working, is possible that the off switch won't reset?
Sep 2, 2007 at 1:08 PM
  • 75,988 POSTS
[quote:45d9d19ca9="R Townsned"]I have the same problem as another person about the fuel pump, but I have a bit of a twist. I pushed the off switch button and gasoline came through the lines. Instead of the gas pump not working, is possible that the off switch won't reset?[/quote:45d9d19ca9]
You must be talking about the inertia switch-if fuel making it thru the line its set-now the question is- is the fuel pressure correct you need to verify that with a fuel pressure gauge.
Sep 2, 2007 at 1:23 PM
