oil light reset?
7,500 MILES • 6 CYL • AWD • AUTOMATIC
BRUCE07727
The message to change the engine oil soon is repeatedly showing at startup. While it is nearing the normal 7500 mile service interval, this service has already been preformed.
I would take it back to them to reset (as I've done before with my previous car) but it is difficult to get there while they are open. Just thought knowing the steps would make it easier.
Thank you in advance.
Bruce
Aug 10, 2008 at 9:37 AM
MERLIN2021
  • 17,250 POSTS
Page 1 of 1 MAINTENANCE REMINDER LIGHT RESET PROCEDURES -2008 Mercury Sable
2008 SABLE
1.To reset the oil monitoring system, press SETUP control to enter SYSTEM CHECK, then press SETUP control again to display "OIL LIE = XXX% HOLD RESET = NEW". 2.Press and hold RESET control for 2 seconds and release. Oil life is set to 100% and "OIL LIFE SET TO 100%" is displayed. 3.While "OIL LIFE SET TO 100%" is displayed, if a lower oil life is desired, press and release the RESET control to reduce the value. Each press of the RESET control reduces the value by 10 percent.
Aug 10, 2008 at 10:02 AM
BRUCE07727
Merlin2021,
Thank you for the prompt & absolutely on target response!!
Bruce
Aug 10, 2008 at 2:43 PM
MERLIN2021
  • 17,250 POSTS
Your welcome!
Aug 10, 2008 at 7:28 PM
