2005 Mercury Sable relays
160,000 MILES • 6 CYL • FWD • AUTOMATIC
DANNYK
  • 6 POSTS
relays on this car keep going bad. so far i have changed wiper, fan, starter, and fuel pump relays on this vehicle , relay module is mounted in front of vehicle. could this be a problem with moisture or a bad voltage regulator .car is running fine now , but some times when i turn the key , is is dead but will start after a couple of key turns . after changing the starter relay . it's fine for another 1000 miles. whats going on
Nov 13, 2009 at 1:59 AM
DANNYK
  • 6 POSTS
[quote:0f0b82fcc1="dannyk"]Electrical problem
2005 Mercury Sable 6 cyl Front Wheel Drive Automatic 160000 miles
relays on this car keep going bad. so far i have changed wiper, fan, starter, and fuel pump relays on this vehicle , relay module is mounted in front of vehicle. could this be a problem with moisture or a bad voltage regulator .car is running fine now , but some times when i turn the key , is is dead but will start after a couple of key turns . after changing the starter relay . it's fine for another 1000 miles. whats going on[/quote:0f0b82fcc1]
Nov 15, 2009 at 9:33 AM
DANNYK
  • 6 POSTS
[quote:3a1c4d60eb="dannyk"]Electrical problem
relays on this car keep going bad. so far i have changed wiper, fan, starter, and fuel pump relays on this vehicle , relay module is mounted in front of vehicle. could this be a problem with moisture or a bad voltage regulator .car is running fine now , but some times when i turn the key , is is dead but will start after a couple of key turns . after changing the starter relay . it's fine for another 1000 miles. whats going on[/quote:3a1c4d60eb]
Nov 17, 2009 at 7:19 AM
