2005 Mercury Sable Keyless Entry Keypad Not Functioning
ANC516
  • 7 POSTS
Electrical problem
2005 Mercury Sable 6 cyl 63000 miles
The keyless entry keypad (on the door, not the remote) on my sable has a bad button. Is there a way this can be repaired or replaced, and if so, is it easy to do yourself, or would it need to be repaired by a pro?
Mar 7, 2009 at 1:46 PM
BMRFIXIT
  • 19,053 POSTS
its not an easy job 1.Remove the front door trim panel 2.Position the watershield aside. 3.Disconnect the exterior door handle actuating rod from the door latch. ? Open the clip. 4. disconnect the electrical connector on keyless entry keypad 5.Remove the bolts and exterior door handle. 6.remove keyless pad 3 nuts 7. remove and replace keyless pad
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_244.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_115.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic3_54.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic4_27.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic5_14.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic6_9.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic7_7.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic8_6.jpg
Mar 7, 2009 at 11:47 PM
ANC516
  • 7 POSTS
Thanks for the help,
One more thing, Where can I find replacement keypads?
Mar 8, 2009 at 8:39 AM
BMRFIXIT
  • 19,053 POSTS
dealer or used auto part place
I don’t think its available through the aftermarket
Mar 8, 2009 at 11:27 AM
ANC516
  • 7 POSTS
Could you give a rough estimate on how much it would cost, with parts and labor, for a dealer/mechanic to replace the keypad?
Thanks again
Mar 13, 2009 at 3:31 AM
BMRFIXIT
  • 19,053 POSTS
Its about 1.5hr to 2 hr of labor
but as parts goes need VIN #
(((my book does not show the price it say call for price )))
you can call your local dealer for price and availability
Mar 13, 2009 at 6:43 AM
