2005 Mercury Sable Car wont turn over
101,800 MILES • 6 CYL • FWD • AUTOMATIC
BHOMAN10
I have a 2005 Merc Sable with 3.0 i replaced the battery a month ago seems to be fine over the last week it has sounded like the battery was low or dead when trying to start had it tested it is good when trying to start it would give the clicking and and slow turn over but would eventually start now even with a good battery it wont do anything when you turn the key to the start posistion but when trying to start it the starter relay under the hood is clicking just to be sure i did replace it still nothing already checked fuses any help would be apreciated
Aug 25, 2009 at 12:52 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a bad starter/solenoid. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it is losing voltage
Aug 25, 2009 at 1:07 AM
BHOMAN10
Thank you Jack i will do
Aug 25, 2009 at 1:10 AM
BHOMAN10
it was the starter i replaced it working good now thank you for your help
Aug 25, 2009 at 8:53 AM
2CARPRO JACK
  • 11,533 POSTS
Happy to help out
Aug 25, 2009 at 9:30 AM
