2005 Mercury Sable camshaft position sensor
62,000 MILES • 6 CYL • FWD • AUTOMATIC
ROBERT PACATTE
does engine need to be top dead center to change out camshaft position sensor sensor on this make and model
Jun 25, 2009 at 12:09 PM
OBXAUTOMEDIC
  • 3,717 POSTS
[quote:68cea9e6a1="robert pacatte"]Computer problem
2005 Mercury Sable 6 cyl Front Wheel Drive Automatic 62000 miles
does engine need to be top dead center to change out camshaft position sensor sensor on this make and model[/quote:68cea9e6a1]
Hi Robert,
No, you don't need to have it at TDC. I haven't run into any make or model that you need to have it at TDC.
Jun 25, 2009 at 12:18 PM
ROBERT PACATTE
can i paypal you a few dollars?
OBXAUTOMEDIC
  • 3,717 POSTS
[quote:39106bd9ca="robert pacatte"]can i paypal you a few dollars?[/quote:39106bd9ca]
Just make a donation to the forum. It is Greatly Appriciated and helps keep the site going.
Jun 25, 2009 at 12:25 PM
ROBERT PACATTE
the car idled a bit rough after the change. so i pulled the negative and reset. then i drove the car for a bit and the rough idle is gone at this time. will see after the car has cooled some. the idle fluctuated a bit. gassed up after a test drive and got an additional 200 extra miles out of the tank. I am grins if this is the best fix i've ever done for twenty dollars. Thank you car pros.
Jun 25, 2009 at 2:04 PM
