2005 Mercury Sable
11,300 MILES • 6 CYL • FWD • MANUAL
FANCY0920
My Mercury will not start at times. All the lights on dash are on and taconometer is ticking. I turn off key and try again. Sometimes I have to do this several times. Sometimes I gently touch gas feed (which I know you are not to do) then it will start.
While engine is hit off after trying to start taconometer will click and slightly move. Have had it to repair and it would not do it while there.
Jan 27, 2008 at 6:13 AM
BMRFIXIT
  • 19,053 POSTS
[quote:2040aa4c98="fancy0920"]Engine problem
2005 Mercury Sable 6 cyl Front Wheel Drive Manual 11,300 miles
While engine is hit off after trying to start taconometer will click and slightly move. Have had it to repair and it would not do it while there.[/quote:2040aa4c98]
no start engine not cranking
check the starter and also check the small S wire on the starter
Jan 28, 2008 at 8:48 AM
