2004 Mercury Sable p1633
80,000 MILES • 4 CYL • FWD • AUTOMATIC
BARBAVY
Engine is running really rough. Stalls at stops. Check engine light was on but went off. AutoZone hoodked a computer to it and the following code came up:
P1633
Thank You
Barb
Jun 14, 2009 at 3:49 AM
BMRFIXIT
  • 19,053 POSTS
If KAPWR is interrupted to the PCM when a breakout box is installed or the battery is disconnected, DTC P0603/P1605 can be generated on the first power-up.
INSPECT the 12-volt battery cables for loose connections and for corrosion.
Jun 16, 2009 at 3:23 PM
