2004 Mercury Sable Overheats when the A/C is turned on.
206,450 MILES • 6 CYL • 2WD • AUTOMATIC
HJIMMYK
I have a 2004 Mercury Sable. It is my work car and I love this car. It has just started to overheat when I turn the A/C on. The coolant is fine has about 10,000 miles since last flush, and is full. The fans turn on. I do not see any signs of a coolant leak.
If I drive with out the A/C on the gauge stays dead center - no overheating. As soon as I turn on the A/C whether driving on city streets or highway it will over heat.
Not sure if it matters but it has the automatic climate control.
Thanks for any help.
Jun 28, 2010 at 11:28 AM
BMRFIXIT
  • 19,053 POSTS
Suspect coolant fan
and check if they operate at the highs speed
check AC high side pressure if very high ,you may have a restriction
Jun 30, 2010 at 2:33 PM
