2004 Mercury Sable mirror
66,000 MILES • 6 CYL • 2WD • AUTOMATIC
PETERBOSSE
I already paid for this once but absolutely no response so I'll try one more time:
The electronic interior mirror in my 2004 Sable is loose and I can't figure out how to tighten it. I can pop off the square (actually it's trapezoidal) cover and I can pull the circuit board down, but I see no screws to be tightened or any other means to tighten the mirror so that it doesn't vibrate and wobble all over the place.
Simple question ~ how do I tighten it?
Simple answer?????????
Thanks
Nov 8, 2010 at 11:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating Sorry for the slow reply. There will be 3 nuts that secure the outside mirror to the door. To access these nuts, you must first the trim panel (triangle piece you speak of) and then remove the water shield. This should expose the nuts shown below.
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_769.jpg
Nov 8, 2010 at 12:00 PM
