2004 Mercury Sable Key less Entry
2004 MERCURY SABLE
MIKE1921
Electrical problem
2004 Mercury Sable 6 cyl Automatic 62150 miles
My key-less entry is no longer working I tried putting the OEM code back in and it will not work either. The power door locks work no problem with the key fob, fuses all look good. Any suggestion's would be greatly appreciated
Thanks, and have a great day !!!!
Jan 25, 2009 at 2:22 PM
BRAVESTAR1
  • 234 POSTS
I would suggest that if the doors unlock, and the doors don't have "locking" issues when you put the car into reverse, and the lights inside go out, that you have a broken wire inside the door.
If your not terribly good at wiring in cars, seek professional help. If you are, it's possible to remove the inner door panel, then locate the keypad on the door, and check for continuity in the wires. However, it can be a pain in the butt to get at these wires, as this system was designed to be watertight, and may be more trouble than it's worth to fix.
Jan 28, 2009 at 12:14 PM
