2004 Mercury Sable Humming noise
66,000 MILES • 6 CYL • FWD • AUTOMATIC
BIOCHM98
When my car is idling at a red light or when I take my foot off the gas pedal and the RPMs drop to idling spped there is a high pitched humming noise. I believe it is coming from inside the air filter assembly and could possibly be the mass air sensor. What do you think? Is this sensor easy to replace or will I need a mechanic to do the job?
Thank you,
Paul Mitchell
Jun 16, 2009 at 2:31 PM
BMRFIXIT
  • 19,053 POSTS
If the sensor at fault you will get a check engine light on and drive-ability issues too
check AIR filter and make sure its installed correctly
check PCV valve and replace
good luck
Jun 16, 2009 at 2:50 PM
