2004 Mercury Sable ENGINE RUNS ROUGH
120,000 MILES • 6 CYL • FWD • AUTOMATIC
SSJRSMITH1
WAS TOLD CYCLINDER 2 MISSING,REPLACED IGNITION COIL,SPARK PLUGS & WIRES.REPLACED FUEL INJECTORS FOR CYCLINDER 1,2, &3.RE-SCANNED.NOW SHOWS CODE PO300,PO302,PO306,&PO316.PLEASE HELP DOWN TO MY LAST END.
Apr 9, 2010 at 11:29 AM
  • 110,248 POSTS
HAve you checked the fuel pump pressure? Also, I'm sure you realize the codes, random misfire, cyl 2... However, regarding the po316, I have found cases of the coil being bad and causing the rough idle, and a bad connection on the B+ wire at the coil. Check that and let me know what you find. Also, you may need to do a compression test to determine if there is a burnt valve...
Let me know what you find.
Apr 10, 2010 at 4:50 PM
