If fluid level is good, regardless of electronics it should at least move when put in gear. Sounds like it may require a tow to a shop. Did thecheck engine light come on when the trans started acting up? If so there may be a code in the PCM stored when the trans failed that could help lead to a fix
SPONSORED LINKS
Sunday, December 28th, 2008 AT 4:09 PM
