2003 Mercury Sable STARTER
BIGBOOKMAN
Engine Mechanical problem
2003 Mercury Sable 6 cyl Front Wheel Drive Automatic 86000. miles
HOW DO I CHANGE THE STARTER. WHEN I TRY TO START MY CAR IT WANT TURN OVER,I HAD THE BATTERY CHECKED AND IT WAS FINE.
May 25, 2008 at 6:27 PM
  • 75,988 POSTS
Better check 1st if you have a problem with the Mega fue/fuse no.7 and no.37 ignition switch/transmission range sensor/starter relay before you get to the starter- Do this have helper hold key at crank position and you go look for power at the white and pink wire at starter-do you have it? If not see below -If so-replace the starter.
https://images.2carpros.com/forum/automotive_pictures/12900_sable_1.jpg
May 25, 2008 at 10:34 PM
