2003 Mercury Sable Rear Lights Staying On
2003 MERCURY SABLE
KANSAS MERCURY
Electrical problem
2003 Mercury Sable 6 cyl All Wheel Drive Automatic
The rear lights are staying on. I"ve tried depressing the emergency brake and releasing it, putting it in and out of Park, turning the lights from the "auto " setting and off again. Even the light across the back window is staying on like I have my brakes on. The keys have been removed from the car for over an hour now. The front headlights are not on, it's just the rear lights.
Sep 3, 2008 at 7:47 PM
Disconnect the brake switch at the brake pedal bracket lights turn off-adjust the switch or replace it.
Sep 3, 2008 at 7:51 PM
KANSAS MERCURY
[quote:a4340c5c87="rasmataz"]Disconnect the brake switch at the brake pedal bracket lights turn off-adjust the switch or replace it.[/quote:a4340c5c87]
Where is the brake pedal bracket where I can find the switch?
Sep 3, 2008 at 8:01 PM
Follow the brake pedal arm till it meets up with the bracket and your there.
Sep 3, 2008 at 8:49 PM
