2003 Mercury Sable Blowing hot air
100,000 MILES • 6 CYL • FWD • AUTOMATIC
SOUTHERNBEL1975
My 2003 Mercury Sable is blowing hot air. 2 cans of R134 we added and still no cool air. I did the self test and was given a code of 888, but have no idea what that means. Thanks.
May 1, 2010 at 8:15 AM
  • 75,988 POSTS
Hi southernbel1975, Welcome to 2Carpros and TY for the donation
Do you hear the clutch engage the compressor??? When you turn AC On? If not possibilities here could be the clutch relay, cycling switch or pressure switch
If the compressor is working -could be the blend air door or the HVAC control unit itself
May 1, 2010 at 10:04 AM
SOUTHERNBEL1975
the cluch is engaging. How much r134 do you need to add? 2 12oz cans were put in and nothing.Thanks for your help.
May 1, 2010 at 10:19 AM
  • 75,988 POSTS
Make sure its not leaking anywhere if not it takes 34oz of freon
May 1, 2010 at 10:37 AM
