spark plug replacement
126,000 MILES • 6 CYL • FWD • AUTOMATIC
PARARDISE1
How do I change the spark plugs?
Aug 14, 2011 at 9:26 AM
  • 55,604 POSTS
The spark plugs are under the ignition coils the rear one will be a little harder to replace so take your time. Here is guide to get you started,
https://www.2carpros.com/articles/how-to-change-spark-plugs
also if you want to replace the ignition coil this video is very informative.
http://youtu.be/iDgXwKA-IIc
Check out the diagrams (Below) it shows how it is done on your car. Please let us know if you need anything else to get the problem fixed.
Sep 5, 2011 at 10:04 PM
CCOLLINS
How do you get to the back 3 spark plugs.
Nov 26, 2018 at 4:21 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Remove upper intake to gain access to the plugs
easier than it looks
good luck
CBROOKE
i have a 2003 mercury sable and it was running fine then the other day it started missing like it needs spark plugs, i replaced the spark plugs and wires in september, and the yellow check engine light came on and is staying on and the car is missing really bad the car has 40, 053 miles
CARUNDELL
  • 602 POSTS
[quote:c04bac1cc4="cbrooke"]i have a 2003 mercury sable and it was running fine then the other day it started missing like it needs spark plugs, i replaced the spark plugs and wires in september, and the yellow check engine light came on and is staying on and the car is missing really bad the car has 40, 053 miles[/quote:c04bac1cc4]
Hey cbrooke
Some things to check would be the wires, look for arcing in places where the wire may have "chafed" against something, the back side of the engine is a common spot. I would also recommend you get the car scanned for codes to see which cylinder is misfiring. Let us know
Chris
TINKERBELL020706
how often do the spark plugs need to be changed in a 2004 mercury sable ?
BMRFIXIT
  • 19,053 POSTS
if not have been done you engine is getting ready for it
if you have a problem make sure you check and or replace the coil
good luck
RACHEL MCCARTY
Hi I need to know the location for spark plugs to a Mercury sable ls premium and the firing order. I think it's 142536 but not sure but I need their location.
Jan 19, 2020 at 3:45 AM
  • 110,248 POSTS
Hi Rachel,
I am going to provide information for a 2004 Mercury Sable 3.0L. If you have the dual overhead cam, it will be the same. I just double checked.
Firing order .................... 1-4-2-5-3-6
The two pics below indicate cylinder location and coil information for each cylinder.
Let me know if this helps.
Jan 19, 2020 at 12:14 PM
MARIELLA DAVIDSON
I need a specific spark plugs diagram for my car and how to change the spark plugs instructions. Also I need the serpentine belt diagram specific for my vehicle and how to instructions on how to change the serpentine belt along with information as to which specific auto part serpentine belt I should purchase. Please help. Thank you for any and all assistance.
May 15, 2020 at 4:14 AM (Merged)
Do you know if you have a dual overhead cam engine or a single overhead came engine? I attached the procedure for the spark plugs. They are the same on either engine.
The belts are different. The SOHC is the first diagram and process and the DOHC is the second.
Here is a video on how to change spark plugs. Clearly it is a different engine but the process is about the same. Also, a guide on how to change spark plugs.
https://youtu.be/sIgLqmfmWgs
  • 55,604 POSTS
One question subject at a time please!
Please post your new question here, you must be logged in.
Cheers, Ken
