Windshield washer does not work
150,000 MILES • 6 CYL • FWD • AUTOMATIC
RMOELKE
  • 5 POSTS
My 2002 Mecurey Sable windshield washer does not work all of a sudden?
Dec 16, 2008 at 12:03 AM
BMRFIXIT
  • 19,053 POSTS
When you activate the switch do you hear it coming on
if so check for leaks and or line
if not suspect the w/w pump
check fuses
locate the pump at the bottom of the w/w tank
check for power and ground when switch activated (may ask a helper to activate THE switch for u )
if it freezing season in your area check that u dont have water in the tank and its frozen
good luck
Dec 16, 2008 at 10:16 PM
