2002 Mercury Sable Should I Use a Chemical Cooling System C
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
RWGUTHRIE
Its been a couple of years since we've flushed the cooling system. Most online advice says to just change the coolant. Should I use a chemical flush? There is a bit of rust in the coolant reservour.
Nov 21, 2008 at 2:32 PM
RACEFAN966
  • 5,029 POSTS
Just use a prestone super flush follow the instructions and then fill like normal with a 70% anti freeze 30% water mix. Thanks
Nov 21, 2008 at 3:20 PM
