I had three Diagnostic Trouble Codes:
1. PO301 Cyl #1 misfire detected
2. PO303 Cyl #3 misfire detected
A code that said something about rough idle under 1000 RPMs.
My mechanic did several tests and used a machine to run some chemicals through the fuel injectors to clean them. The engine runs and idles much better but I noticed the next day when I started it up it idled really rough for several minutes and then smoothed out to a slight misfire. What do you think may be the problem?
Note: I have changed out the spark plugs & wires.
Apr 1, 2008 at 2:07 AM
