Air conditioner noise
77,000 MILES • 6 CYL • FWD • AUTOMATIC
JSTAVITSKI
What would cause my 2002 Mercury Sable to make a loud noise sounds like it is coming from around the pulley system and the air stopped working. It cuts on and blows but does not blow cold air. Both happened at the same time. Bought a charger kit for air and the reader said it did not need to be charged????
Aug 13, 2009 at 1:28 PM
BMRFIXIT
  • 19,053 POSTS
Check AC compressor and clutch assembly. Here is a guide to help you change it out.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Aug 13, 2009 at 1:31 PM
JSTAVITSKI
Does an automatic have a clutch assembly? Would that and the compressor cause the noise as well as the air problems?
Aug 13, 2009 at 1:44 PM
BMRFIXIT
  • 19,053 POSTS
AC compressor has a clutch and bearing where the belt sit check that
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_455.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_226.jpg
Aug 14, 2009 at 10:59 PM
JSTAVITSKI
Thanks so much!! Will the clutch and bearings going bad make the engine light come on as well?
Aug 15, 2009 at 7:34 AM
BMRFIXIT
  • 19,053 POSTS
need to check for DTC
it may be some thing else
that giving you check engine light
codes can help identifying the troubled area
good luck
Aug 15, 2009 at 10:31 AM
BUDDY44
I checked the coolant level which is fine. Not sure what to check next. Thanks!
Mar 13, 2018 at 9:00 AM (Merged)
CEDDY2_
  • 21 POSTS
ARE U HAVING ANY ISSUES WITH THE CAR RUNNING HOT?ALSO IS YOUR TEMP GAUGE READING A LOW TEMP OR AT NORMAL RANGE?
  • 31,937 POSTS
A low temp will often be a thermostat that is stuck in the fully open position, is the engine temp in the normal range or is it showing lower?
TROCK8989
I changed the water pump and the heater started working, 13 months later the heater stoped blowing hot air why did this happen again what should I do please help
  • 110,251 POSTS
Make sure the engine is warming to proper operating temp. Next, with the engine running, warm, and the heater on, feel both heater core hoses. They should be hot. If not, try flushing the heater core. If they are both hot, check the blend air door for proper operation.
LDHICKS
Air Conditioning problem
2002 Mercury Sable V8 Front Wheel Drive Automatic 136000 miles
I turn on ac and extreme heat comes out the compressor does come on but the vent blow out heat not warm air but from the heater, not sure what controls the damper door
  • 110,251 POSTS
You have a problem with the blend air door. On your model year it is either actuated by electric or engine vacuum.
GODOFOUZO
My air conditioner blows HOT air.
This past winter, I inadvertantly hit the A/C button instead of the heat and it started blowing cold.
I immediately hit the heat button...no problem.
Now, that the weather's been getting warmer, A/C just blows hot air.
A/C is fully charged with no leaks
Hoses (tubes) from the condenser get VERY cold but the cold air never seems to make it to the vents.
Anyone have a clue?
Thanks!!
MERLIN2021
  • 17,250 POSTS
Temperature blend door is stuck.
OSLO
2002 Mercury Sable 6 cyl Front Wheel Drive Automatic 95000 miles
air conditionaing blows hot air, next steps
BMRFIXIT
  • 19,053 POSTS
check fuses
check ac compresor if engaging
check gas in system if low (its 134a)
i
2CP-ARCHIVES
  • 4,540 POSTS
heater only blows warm air. engine's temp is normal coolant is ok.what could be the problem?
car does not overheat.
  • 110,251 POSTS
Check the blend air door. It may not be opening fully.
ASHISH SHAH
Heater problem
2002 Mercury Sable 6 cyl Two Wheel Drive Automatic 58000 miles
I had this above mentioned car and yesterday suddenly the fan that blows the hot air suddenly quit working. I mean it would not work at low speed, ( setting 1, 2 and 3 ) but it still works at the full. the problem is that it warms the car too much. How can i fix it that it works on all setting.
BMRFIXIT
  • 19,053 POSTS
Very common for the resister to go bad
replace blower motor speed resister
