2002 Mercury Sable MY car problem
BOONIEBABY06
Engine Performance problem
2002 Mercury Sable 6 cyl Automatic 137640 miles
When i start my car in the morning it takes an extremely long time to isle down. Maybe about 4 minutes. And if i drive off before it is isled down it will jerk when driving. This jerking problem will happen also while i am driving regularly and if i let off the gas and press again it will stop jerking. Not only does my car only jerk in the morning but if i ever pull off before it is isled all the way down it will jerk until i let off the gas and hit it again
Jan 31, 2009 at 9:50 AM
BMRFIXIT
  • 19,053 POSTS
And no check engine light ON ??!!
scan for codes
suspect vacuum leak
check around the PCV valve and hoses
make sure u pinch them if soft and they don’t return to shape replace them
check idle air control valve
Feb 6, 2009 at 10:27 PM
