2002 Mercury Sable cool heat
DARON THOMAS
  • 2002 MERCURY SABLE
  • 6 CYL
  • FWD
  • 77,000 MILES
My heater seems to be working properly(fan running)the heat works just not ho air luke warm this heater always blew super hot air no visible leeks of anykind any ideas?
Tuesday, November 11th, 2008 AT 3:21 PM
RENAUDTN
  • 636 POSTS
What you need to check:
-your level of coolant; make sure it's not low. If low add coolant.
-your thermostat could be stuck open; is your car taking a very long time to get to normal operating temp?
-your heater core: with engine on at normal temp and heat on high, both inlet and outlet hoses to the heater core should be very hot. If one is not, or significantly colder than the other, your heater core is probably clogged. Flush it or replace it.
-your blend door actuator or the blend door is defective. Broken blend door is a common problem for your car. Can you hear the door moving when you turn the switch from heat to cold or vice versa?
Hope this helps to diagnose your problem.
Thursday, November 13th, 2008 AT 12:13 PM
