2002 Mercury Sable Back Power Windows
74,151 MILES • 6 CYL • 2WD • AUTOMATIC
BREEZE5
when pressing the button on both back window they do not go down. The window locks are unlock. Also when I press the master switch on the drivers side they still do not operate. The two front window work just fine. I do have and owners manual because I assume that it might be a fuse. But it does not show which one are the power windows. Can you help me please?
Aug 10, 2008 at 10:21 AM
BMRFIXIT
  • 19,053 POSTS
its a window motor (one fuse all windows )
u need to remove the door panel and check for power at the motor
in some very rear times if u tap on the motor will get it going for some time
and if so motor no good for sure u have a flat spot
good luck
Aug 14, 2008 at 2:05 AM
