2002 Mercury Sable
TRIXXIT54
  • 2002 MERCURY SABLE
2002 Mercury Sable
how do you install an input speed sensor on a 2002 mercury sable?
Thursday, January 7th, 2010 AT 1:44 PM
MERLIN2021
  • 17,250 POSTS
There are two, the output shaft speed sensor and turbine shaft speed sensor, both on the trans axle, unless you want the wheel speed sensors for anti lock brakes?
Thursday, January 7th, 2010 AT 2:05 PM
TRIXXIT54
No brakes. The problem is the car won't shift out of first gear and the rpm's keep going up. Someone told me it was the input speed sensor.
Thursday, January 7th, 2010 AT 10:12 PM
MERLIN2021
  • 17,250 POSTS
Sounds more like a transmission problem to me. Is the check engine light on? If yes first step is to read the codes, even if you need to buy the scantool and bring it to the car! Autozone reads the codes for free, try shifting it manually, start in the lowest gear 1 and shift up with your shifter, does this help? Check fluid level and color.
Friday, January 8th, 2010 AT 3:02 AM
