2002 Mercury Sable
2002 MERCURY SABLE
66,000 MILES • 6 CYL • FWD • AUTOMATIC
SQUIDWARD
Squeaking noise coming from area where transmission bolts onto engine. gets quieter when engine gets hot. Sounds something like a  bad water pump sound but is definetly coming from engine/transmission area
Mar 13, 2009 at 11:39 AM
JAMES W.
  • 2,394 POSTS
Does the "squeaking noise increase/decrease with engine speed? Does it make a difference with trans in drive or neutral? Is the squeak evident going down the road, or only when stopped? Please advise.
Mar 13, 2009 at 5:14 PM
SQUIDWARD
Noise is there when in or out of gear. When going down the road, it is not noticable, seems to quiet down when engine rpm increases. Noise is much less after engine/transmision gets hot.
Mar 13, 2009 at 11:25 PM
JAMES W.
  • 2,394 POSTS
From what you describe, it has all the symptoms of a cracked weld on a heat shield either on the exhaust system or the catalitic converter. Let me know.
Mar 14, 2009 at 8:07 AM
