PCV Valve Location
JOYFUL0022
Engine Performance problem 6 cyl Front Wheel Drive Automatic 52,000 miles
Want to replace the PCV Valve, but can't find the location. Car is 3.0 L, DOHC, 24 Valve. Can you help me?
May 29, 2010 at 7:16 AM
  • 55,849 POSTS
This PCV valve is not a typical location valve. This valve is located down in by the throttle body. Here are some diagrams (below) that will help you get the job done.
Cheers, Ken
Feb 5, 2019 at 10:13 AM
RICARDO CENICEROS
What key you use for the valve?
  • 55,849 POSTS
I am not sure what you mean. can you give me more details?
Cheers, Ken
RYDER SEEDS
What is the best way to pull the old valve out. Have gotten to the point of pulling everything but the old valve. Can not get it to move using pliers or anything else. Car has way to many miles on it for this old one to still be on.
  • 55,849 POSTS
This can be tough because the rubber grommet becomes brittle not allowing the valve to be removed, try heating it up with a hair blower and pry it out of there is the grommet breaks you will need a new one.
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
