2001 Mercury Sable P0304
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
B&E
P0304 Cylinder 4 misfire, check engine light on flashes on and off, done wires, plugs, coil, crank and cam sensors, did compression test low 100's in cylinder 4, all others are good, clean carbons, runs better compression came back up, check engine light on again, on and off. fuel pressure in range 55psi. Checked for vacuum leaks none found. new intake plen. gasket. I have no clue of what else. Any help would be greatly appreciated.
Aug 26, 2010 at 4:26 AM
  • 75,988 POSTS
Check the injector for no.4
Aug 26, 2010 at 6:02 AM
