2001 Mercury Sable fuel pump problem
104,000 MILES • 6 CYL • FWD • AUTOMATIC
HARPWH23
fuel pump not starting intermittently. relay cycling ok 2 seconds with key on without failure, remove relay and jump 12 volt and fp lead pump comes on 8 out of 10 times. could inertia switch have dirty n/c contacts and where does the fuel pump ground lead terminate on chassis
Jan 12, 2010 at 5:18 AM
BMRFIXIT
  • 19,053 POSTS
if switch fail will not start at all and need to be reset
if relay Supplying power
Suspect pump module
Jan 16, 2010 at 11:31 PM
HARPWH23
[quote:e9f6a7b0ff="BMRFIXIT"]if switch fail will not start at all and need to be reset
Suspect pump module[/quote:e9f6a7b0ff]
Reply from sender:
Found problem to be a high resistance ground, ran sepatate ground wire from black wire of pump harness (ground side of pump motor) to chassis.
Working fine now.
Thanks for your asistance.
Jan 17, 2010 at 12:38 AM
BMRFIXIT
  • 19,053 POSTS
Thank you for posting your finding and the fix so others can benefits from it
Jan 17, 2010 at 8:26 AM
