When the car is hot, been running awhile, and I turn it off, it won't restart. It cranks, but weird. It might catch, but then won't keep running. I step on the gas and it dies completely. I need to wait 20-30 min, presumably to cool off, then it will start fine and run fine. There was a check engine light and it was diagnosed as running lean. Several things were fixed including intake gasket and fuel filter. Light is off but still have the problem. Then a Ford bulletin suggested idle control valve, which I replaced. But still does the same thing. Help??
Nov 26, 2009 at 3:32 AM
