2001 Mercury Sable Engine light and stalls when idle
2001 MERCURY SABLE
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERT.HOLLON
MY 01 Merc Sable check engine light came on, right after the light came on the car begin to idle high and low when you stop. At a red light, stop sign, etc...
It recently began to cut off because the idle was so low when sitting, it drives and seems to run fine when moving. Please help
Jul 28, 2009 at 10:53 AM
  • CAR REPAIR CONTRIBUTOR
Last tune-up?
1st thing to do here is get the computer scanned for OBD2 code/s this will indicate what's causing the CEL to come on. Autozone provides this service free of charge.
Idle fluctuating could be the idle air control valve, TPS and MAF sensors, also check the fuel pressure to include the PCV and EGR valves.
Jul 28, 2009 at 1:53 PM
