2001 Mercury Sable engine is missing
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
LARRYCONLEY
My car misses. Likie it's only running on 2 cylinders.
Jan 6, 2010 at 3:57 AM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 6, 2010 at 9:57 AM
