2001 Mercury Sable blower motor
2ND MERCURY
Heater problem
2001 Mercury Sable Front Wheel Drive Automatic 52,000 miles
The blower motor is no longer working, I have changed the fuses and relay under the dash. What else can I check, and is it worth trying to do myself, as I am no mechanic. Thanks whomever
Nov 10, 2008 at 12:43 PM
IMPALASS
  • 3,112 POSTS
Hello
Do you have a manual AC/Heat system or the automatic? Also, what size engine do you have?
If your blower motor is not working at all, I would think it is bad. It is not hard to change or check. Would you like the info on it?
If so, please provide if it is a manual or automatic AC/heat system and the engine size.
Nov 10, 2008 at 12:50 PM
