How do I remove and replace the water pump?
MGOOSE
how do I remove and replace the water pump?
Oct 8, 2010 at 2:16 PM
FACTORYJACK
  • 4,159 POSTS
I saw your other post stating DOHC. See if this helps Removal and Installation Drain the cooling system.
https://images.2carpros.com/forum/automotive_pictures/309872_84796135_1.gif
Disconnect the lower radiator hose and heater hose from the water pump. Lower the vehicle. Remove the accessory drive belt.
https://images.2carpros.com/forum/automotive_pictures/309872_84796136_1.gif
Disconnect the hose.
https://images.2carpros.com/forum/automotive_pictures/309872_84796137_1.gif
Remove the bolts and the A/C compressor support brace.
https://images.2carpros.com/forum/automotive_pictures/309872_84796138_1.gif
Remove the four nuts and the water pump. To install, reverse the removal procedure.
Apr 25, 2021 at 5:49 AM
SQM
  • 6,383 POSTS
For anyone who might be looking for water pump replacement instructions, I have attached both of the 3.0 OHV and 3.0 DOHC engine's water pump replacement procedures.
https://www.2carpros.com/articles/water-pump
https://www.2carpros.com/articles/water-pump-replacement
Oct 22, 2021 at 6:50 AM
