2000 Mercury Sable Starting
TRU3ME
Engine Mechanical problem
2000 Mercury Sable 6 cyl Front Wheel Drive Automatic
i Have a 2000 sable and it doesn't start. the battery is good but won't start. think it might be starter, not sure. don't even know where it is located.
Aug 2, 2010 at 1:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
does the engine try to crank at all or just getting a click noise? one click than probably starer, multiple clicks then faulty charging system. to find starter just trace positive battery cable down engine compartment, will lead to starter.
Aug 2, 2010 at 1:02 PM
TRU3ME
the car does crank
Aug 2, 2010 at 1:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if it's cranking then starting and charging systems are good. can you hear the fuel pump come on when you first turn key without cranking? if not then fuel pump fuse or relay maybe bad.
Aug 2, 2010 at 1:14 PM
